I've been unable to connect to my PC host and Android phone hosts for a couple of days now. I've checked my PC host TV log, please see below
It seems the connection keeps getting timeout for unknown reason. The timeout takes place in only 5 seconds after attempting to connect. And it leads to "router connection failed" error
Not sure if it is my local network problem, or server side issue? On my end, I didn't change any network configs. I've tried reinstalling all the TV apps on both server and client ends.
Appreciate any advice on the reason why connection is getting timeout. Thanks
2024/10/11 08:54:48.270 5332 8968 S0!! DriverConfiguration::GetPortNumber() RegOpenKey failed: 2
2024/10/11 08:54:48.271 5332 8968 S0 ClientWebAPI: started accept server on port 37014
2024/10/11 08:54:48.271 5332 8968 S0 ClientWebAPI: started accept server on port 37114
2024/10/11 08:54:48.271 5332 8968 S0 Activating Router Carrier
2024/10/11 08:54:48.271 5332 8968 S0 CommandHandlerRouting[276]::CreatePassiveSession(): incoming session via hk-hkg-anx-r002.router.teamviewer.com, protocol Tcp
2024/10/11 08:54:48.317 5332 8956 S0 CTcpConnectionBase[278]::HandleResolveSuccess(): Connecting to hk-hkg-anx-r002.router.teamviewer.com
2024/10/11 08:54:48.317 5332 8956 S0 TcpConnectorv4[278]::ConnectEndpoint(): Connecting to endpoint xxx.xxx.xxx.xxx:5938
2024/10/11 08:54:53.317 5332 8960 S0 TcpConnectorv4[278]::HandleConnectTimeout(): Connect timed out
2024/10/11 08:54:53.317 5332 8960 S0! CTcpConnectionBase[278]::HandleConnect: Connect aborted to dest-ip hk-hkg-anx-r002.router.teamviewer.com:5938 with error system:995.
2024/10/11 08:54:53.317 5332 8968 S0!! CommandHandlerRouting[276]::HandleConnectPassive(): connect failed!
2024/10/11 08:54:53.317 5332 8968 S0!! CreateIncomingClassicSession::StartSession: router connection failed
2024/10/11 08:54:53.318 5332 8964 S0 ClientWebAPI: stopped accept server on port 37014
2024/10/11 08:54:53.318 5332 8960 S0 CAcceptServer[127.0.0.1:37014]::HandleAccept(): Accept canceled
2024/10/11 08:54:53.318 5332 8968 S0 CAcceptServer[127.0.0.1:37114]::HandleAccept(): Accept canceled
2024/10/11 08:54:53.318 5332 8964 S0 ClientWebAPI: stopped accept server on port 37114
2024/10/11 08:54:53.319 5332 8964 S0 IConnection[278]::~IConnection(): Count: 1
