Check and Track Incoming Log and IP Details
Just few days ago some one enterted my computer through teamviewer and stole my important document. I got shocked that some one connected to my computer just 2 days before while i was also using computer same time. Unfurtunately i did not get see the username of incomming user coz he disconnected instantly when he knows im also using computer on that time.
Mostly my computer is running 20-24hr for internal server usage, So i need kind support to track and check that unknown incomming user details. How to do that. Plz suggest me.
Hello. It is very easy to get to know who was connected to your machine at any moment - just open log file localised in C:\Program Files (x86)\TeamViewer\Connections_incoming.txt - there you will see machines' IDs that estabilished an incoming connection to your machine. Finding out exact IPs of machines may be difficult - I think only TeamViewer authors know them.
5 -
For those who are having this problem make sure you have updated the default 6 character key to something stronger. Someone entered my computer through teamviewer and I have a theory that scammers are pinging the id until they get a hit. For those of us who never shutdown our computers the default 6 character password never resets so the scammers can just ping away until one day they get through.
Teamviewer allows a rotating very secure password of 10 characters, I'd suggest perhaps entering your own very strong 14+ charatcter password. 6 character passwords don't take all that long to break, in my opinion the 6 should not be the default minimum, it should 10 at least.
I have learned a ton since getting hacked and I think I'm onto something...
3 -
Is there a log thats shows out going sessions ?
I second this. Tonight I noticed that my mouse was moving on my PC. I was in bed when the light came on. I leave my computer on and Teamviewer running too. I changed my settings to the 10 characters. I have 2 factor enabled too so I was surprised anyone can get in. Teamviewer needs to address this.2
fRED-PC 06-09-2017 03:08:59 06-09-2017 03:52:04 Ana RemoteControl {B2C8C288-9D49-49B7-98E3-76AAE1E39B0B}
FRED-PC 11-09-2017 02:23:39 11-09-2017 02:29:40 Ana RemoteControl {308F3179-4022-4120-96AA-8A67CFF0BF47}
FRED-PC 20-09-2017 02:28:33 20-09-2017 03:00:17 Ana RemoteControl {525F9E84-BB34-4A5F-9A0A-D041425FD106}
FRED-PC 20-01-2018 17:16:06 20-01-2018 17:25:34 Ana RemoteControl {87AFBC6C-BFC9-4D74-8577-23FA01499E1F}
FRED-PC 10-03-2018 03:37:00 10-03-2018 03:46:50 Ana RemoteControl {EE64AABB-0057-4B6D-8154-697C0ECE2BE9}
FRED-PC 20-04-2018 17:54:56 20-04-2018 18:49:12 Ana RemoteControl {0B5A22A1-13D7-46AD-AB66-7843D347C4B4}Can you guys help me please. the times such as 3 and 3:46 means that someone remotely connected with me at 3:00 am without my knowledge..also what does the codes in the last coloumn represent?
Quick question here.
How did you get to the log file?
I have the same query, where can we use the codes in the last column of the incoming logs on our investigation1
This log stores only the established connections.
Where can I see the trials? Who try to connect to my PC?
BR
KulGery
