When using chrome OS, if I attempt to connect to a computer in my LAN using a local IP, teamviewer seems to not understand the IP, instead trying to parse it as a teamviewer ID
For example, using the teamviewer ID 192.168.1.12, I get the following error: "The teamviewer ID 192 you have entered does not exist". So it seems that IP parsing wasn't implemented in the chrome OS version of teamviewer, or maybe its just a bug.
Thanks!
