I would like to take remote control a Mac. I have a PC under Windows 10. Is it possible? Excuse my English I am French.
Thank you.
Should be no problem at all.Apple support depends on MacOS version though.
I'm not sure what has changed but I'm no longer seeing this problem. I did file a report with Teamviewer so perhaps something was changed. I have been using TV 13 for about a month and have consistently without exception had the issue I reported. Go figure. Seems to be no longer an issue.
Thanks to any of you who spend any time thinking about this.
Unc
Problem accessing Filemaker app from HP Spectre Win 10. The FM app is on a macOS 10.13.3. Is there a support page that shows supported OS compatability?
Remote control from my iPad (IOS 11.2.6) works fine.
Description of issue.
Calendar fields configured with an icon to show/hide the calendar. Click icon produces erratic results. Usually just selects the field as if I had clicked in the field and does not display the calendar. Occasionally, clicking the icon will cause the drop-down calendar to appear momentarily only. I’m able to enter keystrokes in the date field as designed.
thank you !
