I am connecting a Windows laptop to a Mac. When connected the remote Mac keeps acting like the letter "a" is being pressed. When I disconnect it stops. Any thoughts on how to make it stop?
Actions->Disable Remote Input option is greyed-out on Windows client when accessing Mac. The option doesn't appear to exist, as represented, on the Mac host when I view TeamViewer options on the Mac, while a remote PC is accessing it. Unclear, therefore, how to "Disable Remote Input" in a session to determine whether issue exists on the Mac or the TeamViewer PC client that's accessing it.
I will offer that accessing the same Mac from the same Windows 7 client, using GoToMyPC does not produce these spurious "a's." I'm only attempting TeamViewer usage, because I'm dissatisfied with GoToMyPC for other reasons (mainly cost). I sure with TeamViewer would work without error!
You could try disabling remote input.
If the problem stops, you know the "a" is coming from the Mac.
