Is there a way I can start a remote session with the bottom left remote panel minimized? Too many times customers click the X instead of minimizing.
Hello BarcodeUK,
If you log into a costumer's pc you can click the minimize bar yourself. I am looking for a solution for you're problem i'll reply if i have one!
I hope this helps.
