Problem with teamviewer connection
Vietnguyen010
Hi guys,
After a month of headaches to fix my Teamviewer can't connect to network and it says "Not ready, Please check your network connection" you can see under images (latest picture).
I know this is a very popular question but believe me, I've read all the related topics, try every single way which I found but I can't solve my problem. Here is my short version of TeamViewer log, you can view full log here http://textuploader.com/dlpe7
2017/11/10 10:47:33.911 3708 5180 S0 CProcessCommandHandlerMasterConnect[812]::CreateMasterConnect(): master3.teamviewer.com:80, Connection 812, proxy=''
2017/11/10 10:47:33.925 3708 5184 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master3.teamviewer.com
2017/11/10 10:47:33.925 3708 5172 S0! CProcessCommandHandlerMasterConnect[812]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/11/10 10:47:33.925 3708 5172 S0!! LookUpDNS failed for master3.teamviewer.com, socket error = 11001, Errorcode=11001
2017/11/10 10:47:33.925 3708 5172 S0!!!Connect to Master master3.teamviewer.com / failed!, Errorcode=11001
2017/11/10 10:47:33.925 3708 5172 S0!! CMasterConnectorAsio::HandleMasterResponseRegister(): MasterConnect failed. ErrorCode=10, Errorcode=11001
2017/11/10 10:47:36.925 3708 5180 S0 Activating Router carrier
2017/11/10 10:47:36.926 3708 5180 S0!!!CTcpConnectionBase[813]::HandleResolve(): Resolve failed, ping3.teamviewer.com, Error: system:11001
2017/11/10 10:47:36.926 3708 5172 S0 Activating Router carrier
2017/11/10 10:47:36.940 3708 5180 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/11/10 10:47:36.940 3708 5180 S0!! Port443Connection::ConnectInternal: failed with HTTP status code = 0
2017/11/10 10:47:36.940 3708 5172 S0 Activating Router carrier
2017/11/10 10:47:36.956 3708 5172 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: ping3.teamviewer.com
2017/11/10 10:47:36.957 3708 5180 S0! CKeepAliveClientClient::HandlePing(): ping failed
2017/11/10 10:47:36.957 3708 5180 S0 Activating Router carrier
2017/11/10 10:47:36.957 3708 5180 S0 CProcessCommandHandlerMasterConnect[816]::CreateMasterConnect(): master11.teamviewer.com:80, Connection 816, proxy=''
2017/11/10 10:47:36.972 3708 5172 S0!! HttpRequestImpl::CurlFinished(): curl request failed: Couldn't resolve host name (6), Could not resolve host: master11.teamviewer.com
2017/11/10 10:47:36.972 3708 5176 S0! CProcessCommandHandlerMasterConnect[816]::HandleMasterConnect(): MasterConnect to 0.0.0.0 failed
2017/11/10 10:47:36.972 3708 5176 S0!! LookUpDNS failed for master11.teamviewer.com, socket error = 11001, Errorcode=11001
2017/11/10 10:47:36.972 3708 5176 S0!!!Connect to Master master11.teamviewer.com / failed!, Errorcode=11001
2017/11/10 10:47:36.972 3708 5176 S0!! CMasterConnectorAsio::HandleMasterResponseRegister(): MasterConnect failed. ErrorCode=10, Errorcode=11001
Here is what I have done but not fix.
- Remove Teamviewer with Revo Uninstall Pro with clean advanced delete leftover files.
- Re-install network driver / disable all other network driver excepts Wifi adapter
- Disable IPV6
- Disable all firewall, Antivirus
- And bunch of other ways...
I use Wireshark to listen to connection request on Wifi adapter but nothing related to Teamviewer appear but when I use Teamviewer v11, magically is working fine I got that error when use v12 and above.
Please help.
