I Tried to Connect to Partner system by using the Same version, I'm getting the error message that A Connection Could not be Established. Reason Unknow. But my Partner is Able to Connect to my System. I tried to Connect to other partner Systems and successfully connecting to those systems too . Anybody help about to solve the issue?
My License has expired and I'm trying to repurchase but don't know where to go to purchase it?
Thanks, @Goico ! That worked for me. Updating the TeamViewer app worked!
To fix that problem, only you need Update your Teamviewer and your partner too.
I am facing this problem as well. Hence I wasn't able to find any working methods from this topic, I googled a lot and I updated the teamviewer version as mentioned in this article to match with the version of the teamviewer with the other person. This is the link (https://forumbap.com/t/teamviewer-cant-connect-reason-unknown/1374/). I was able to solve the issue for a couple of days...
From yesterday, the same issue came back, and I couldn't resolve it with any of the methods mentioned here or on any article on the internet. So, can any of your support guys tell me what could I do? Please help me. I would greatly appreciate it. I have been trying fixes for almost 2 whole days now.
I met this issue too. I solved it by updating Teamviewer. The problem for me is I used an outdated version.
Rebooting both PCs did not work for me. However, I made it work by killing all teamviewer services (This PC->Manage, Services...) on the local PC, then start Teamviewer as usual.
What easily worked for me was to UNISTALL Teamviewer from one of my computers, without unistalling settings or preferences, then REINSTALL it...!
I having this issue where i will not connect, been using for 5 years now it wont connect.
The reason I cannot connect to a certan client is that TV changed the ID of clients on 07-24-18 without notification. Customer support recoments to close/ restart TV for each client. I did this and it worked out for me. I hope for you too.
@twodays ago everything was ok but as I connected to TV most of my clients has blue question mark and I could not access them. All the other ones no problem. IWe are running TV 5.1.17330 since 8 years with out any problems. Did you got your problem solved?
Was your issue resolved? I am having the same problem..
TW are changing the IDs so i think we have to wait a bit more time
Roughly 50% of my Partner list has Blue Question Marks suddenly and Connection Could not Be Established on 50% of the ones that look ok in my list.
Was ok first thing this morning.
a lot of people are going back to 12 and it works fine. I find using my VPN makes it work fine
When people like "Portmeyers" above post their problems and you give them a solution, and they don't bother acknowledging it with a simple thanks, it makes one less and less inclined to help the community. It is not as if we are employees of TV and we are under no obligation to respond to help requests. Why bother
Hi all, I had this problem just now, I logged out teamviewer and logged in. All fine then. Hope it helps. Cheers!
Yes, it is a power thing. I doubt that v13 caused the problem, though as stated before, there are other issues with it - which is why I reccomend and use v12 despite having purchased the v13 license. Now as for you power issue, it is likely that the settings were inadvertantly changed, or an MS patch has modified your power-settings. I do not use Windows 10 (still and always will be on 7) but I am sure there are similar settings. As I said above, look for "Advanced Power Settings" or something similar. There you will find many options to fine-tune your power-management. It will probably be there that you find your solution to having the computer remain awake but still save power. Things like turning the display off and some hardware features, but still having esssential services run like TV. Try them one-by-one and you will find the culprit.
FYI, I changed the timeout/sleep settings and I can connect unattended now although now my screen at the home computer no longer goes to sleep to save on electricity. It worked before so I assume updating to version 13 caused the problem.
This has nothing to do with white or blacklists. The computer is already accessible to you. It is just going to sleep.
It sounds to me like your computer is going to sleep, entering a semi-shut mode where teamviewer and other running services are suspended. Your wife wakes up the computer and teamviewer along with it. Search for "sleep" and look through the settings of the "Change when the computer sleeps". Try setting it to stay awake permanently, and if that cures it - go in again and start to adjust power settings until you find the culprit. There are settings under "advanced" that can affect running services.
As an aside I rolled back to v12 as there are very specific issues with 13. I always advise waiting for at least 6 months after a major release before upgrading.
You should verify the settings in the affected computer (one that's inaccessible)
They can be accessed by the teamviewer application (Extras (in title bar) -> Options -> Security -> Blacklist and Whitelist
I will recommend adding the other computer to the whitelist of the affected one, so it should be always accessible
I'm using Windows 10. What did you add to the white/blacklist i.e. teamviewer.com or something else?
Which OS are you using? My windows 10 based teamviewer is working fine even after update.
Although, I have one running on my linux machine. It stopped working presumably after updating to teamviewer 13. But I was able to get it back to work after fiddling with its 'Blacklist' and 'Whitelist' settings in its options (Extras -> Options -> Security for windows).
I'm getting the a pop window that says "unable to connect" teamviewer not running on partner computer. it is running. The computer that wont' connect is my home computer. I have my wife wake up the computer by touching any key on the keyboard and then it shows online.
This was working find for months. I assume either a teamviewer or microsoft update caused the problem. I uninstalled teamviewer on my laptop and home computer and reinstalled and they did not help. Any ideas, i.e. something changed in version 13?
Fixing blacklist and whitelist fixed it for me
Which versions of Teamviewer are being used - you should NOT use version 13 yet - on either side. It has issues. Wait for them to release a more stable version. For now I use version 12 on both sides and all my issues went away
I found that logging on to my VPN lets me connect, but any other attems directly fail to all computers. This has been going on for a long time. Windows 10 Pro, AT&T fiber optics
Another TV alternative for Windows is *bleep*. You can download it from here -
[competitor link removed by Moderator]
FYI., this TeamViewer error 'Connection Could not Be Established' got resolved by itself. The only thing I remember I did was updating it to the newer version.
Thanks,
Syed Abdul Raafay
Many connections not working (same issue here) and there is no update? No response from TeamViewer?
Instead of a fix, could someone suggest me another app/program?
