Weird shaking issue
Using Linux Mint 18.3. I installed the latest version of TeamViewer on my Windows and Linux boxes.
When I remote into my Linux box from Windows, I get this weird screen shaking issues. Like all the pixels vibrate back and borth non-stop. When I reverse this and go from that Linux box to Windows, no problem.
I tried adjusting the display from auto to quality/speed and makes no difference. Any suggestions?
  • DanielStm
    My Mint loving colleague said this is a long standing problem, seems to be a driver issue.
    You might be able to get rid of it by using a different driver, or staring the desktop in software rendering/compatibility mode, or by using a different graphics adapter.
    Linux Developer
  • Thanks for writing back! I'm using the default gfx card built into my motherboard, Gigabyte GA-Z170X-UD5, which uses Intel HD Grpahics.
    I'll try tossing in a new video card or running Cinnamon in software mode. Since this is just a Plex server, I don't really have need for accelerated graphics. I was just going to set it up headless but using the GUI for doing certain things is a bit faster/easier than the command line.
