When I try to listen to audio from the remote computer, the audio doesn't work. I have checked, and the setting is checked off. Using Windows 8.
I need help. Sound doesn't work for days and then boom sound works out of no where and then next day does not work again. What is going on!
Any news? I'm using Debian 9.5 Stretch with Gnome and I'm trying to get audio from my Windows 7 pc but the audio settings can't even detect Teamviewer application. Using Teamviewer 13 on both machines. Please don't force me to install Windows on my computer just for this!
Same issue. Where must I check if sound configuration is correct?? I think I've checked it all...
I am using Linux Lite 3.6 Release 16.04 where I have installed the latest updated version of TeamViewer (13.1.3026), and sound works well if I reproduce mp3's or online radio locally. But If I connect remotely to my Windows Desktop 7 through TeamViewer, I cannot hear the sound from the remote Windows. It only happens if I connect from Linux. From mobile or other Windows it works ok.
Please, any solution??
I have the same issue. Any fixes?>?>?
