Been using teamviewer awhile , but ive ran into some kind of problem
Using a computer that is running teamviewer 13 its connected on the same lan that im using at home , but its using a vpn service .
But when using teamviewer on it it can suddenly stop working
in the unit list sometimes that computer goes black , and i cant reach it anymore
and at the moment im connected to the computer , and its stated
Not ready , Check internet connecton
IF im not connected via vpn service it works just fine ....
018/01/11 08:35:29.372 2400 2520 S0! CTcpConnection[121]::KeepAliveBeepTimerHandler(): No KeepAliveBeepAnswer was sent. Stopping connection.
2018/01/11 08:35:41.372 2400 2524 S0 IConnection[121]::HandleShutdownTimer(): Shutdown of connection took longer than 12 seconds. Closing Connection. (ConnectionType Type_Tcp)
2018/01/11 08:35:46.373 2400 2516 S0 CTcpConnectionBase[122]::HandleConnectTimeout(). Connect timed out to server24908.teamviewer.com:5938
2018/01/11 08:35:46.373 2400 2524 S0! CTcpConnectionBase[122]::HandleConnect: Connect aborted to dest-ip server24908.teamviewer.com:5938 with error system:995.
2018/01/11 08:35:52.374 2400 2520 S0 CTcpConnectionBase[123]::HandleConnectTimeout(). Connect timed out to server24908.teamviewer.com:5938
2018/01/11 08:35:52.374 2400 2528 S0! CTcpConnectionBase[123]::HandleConnect: Connect aborted to dest-ip server24908.teamviewer.com:5938 with error system:995.
2018/01/11 08:36:01.374 2400 2524 S0 CTcpConnectionBase[124]::HandleConnectTimeout(). Connect timed out to server24908.teamviewer.com:5938
2018/01/11 08:36:01.374 2400 2520 S0! CTcpConnectionBase[124]::HandleConnect: Connect aborted to dest-ip server24908.teamviewer.com:5938 with error system:995.
2018/01/11 08:36:11.376 2400 2524 S0 CTcpConnectionBase[125]::HandleConnectTimeout(). Connect timed out to server24908.teamviewer.com:5938
2018/01/11 08:36:11.376 2400 2520 S0! CTcpConnectionBase[125]::HandleConnect: Connect aborted to dest-ip server24908.teamviewer.com:5938 with error system:995.
2018/01/11 08:36:21.292 2400 2516 S0! UdpConnection[14]: UDP statistics: scf=2
2018/01/11 08:36:21.377 2400 2520 S0 CTcpConnectionBase[126]::HandleConnectTimeout(). Connect timed out to server24908.teamviewer.com:5938
2018/01/11 08:36:21.377 2400 2524 S0! CTcpConnectionBase[126]::HandleConnect: Connect aborted to dest-ip server24908.teamviewer.com:5938 with error system:995.
2018/01/11 08:36:22.901 5288 4364 H64 explorer.exe: ResumeAllThreads: resumed 19 threads, max count 19
2018/01/11 08:36:22.901 5288 4364 H64 explorer.exe: DragInterceptor: interception successful (new interface)
2018/01/11 08:36:31.378 2400 2516 S0 CTcpConnectionBase[127]::HandleConnectTimeout(). Connect timed out to server24908.teamviewer.com:5938
2018/01/11 08:36:31.378 2400 2528 S0! CTcpConnectionBase[127]::HandleConnect: Connect aborted to dest-ip server24908.teamviewer.com:5938 with error system:995.
2018/01/11 08:36:33.731 3840 3264 G1!! CopyMarshalledStreamToBAT: unable to unmarshal inter thread interface, hr= -2147417827
2018/01/11 08:36:33.731 3840 3264 G1 CClipboardController::SendClipboardContent: (11 data formats)
2018/01/11 08:36:41.379 2400 2520 S0 CTcpConnectionBase[128]::HandleConnectTimeout(). Connect timed out to server24908.teamviewer.com:5938
2018/01/11 08:36:41.379 2400 2528 S0! CTcpConnectionBase[128]::HandleConnect: Connect aborted to dest-ip server24908.teamviewer.com:5938 with error system:995.
Need to open port to get it working ? Port 5938 ?
waitforconnectfailed is coming up when im trying to connect to it
