Key combos not being sent to remote PC in KDE 5.8
atmarx
atmarx Posts: 4
Anybody else running KDE 5.8 that can test out sending remote key combos?  I could swear they worked in 5.7, and I already submitted a bug to the plasma and kwin projects, but was told (of course) that it's not their issue...
Any alt+{key} and meta+{key} combos get gobbled up by the host instead of TV capturing them to send remotely.  Maybe there's different hooks in KDE vs whatever other DE the TV devs test in?
  • S_Mueller
    S_Mueller Posts: 4 ✭✭
    Hi, I use openSuSe 13.2 with KDE 4.14.9 along with TV11 and have the same problem.
  • I've tested it in Gnome 3.14 and 3.22 under Debian Jessie and Stretch with the same results.  Current (**bleep**) solution is to run TV in a Windows VM.  Not great, but I can't be nearly as productive on a remote system without keyboard shortcuts.
    C'mon, TeamViewer devs -- can we please get key combos working on Linux?  When I wrote in to the TV support, the tech said he would file it as a feature request instead of a bug.  IMHO, if there's a button that says "Send key combos" and it doesn't work, it's a bug.
