I upgraded both of my PCs to the new Beta version and all is running smoothly with the Android Apps now. But the Web-Interface tells me, that my Client isnt up to date and is not supporting the webinterface. Is that always with the Beta-Version?
Hi madhatter84,
You are very fast
Our development puslished an update - it should work now.
Cheers,
Julia
Thank you for your fast update :-)
It's working now, thanks for the update.
This is currently a bug in our Management Console - our development is already working on it.
A workaround is to use the fullversion. If you are not allowed to install it on the computer we recommend you to choose "run" instead of an installation.
I will inform you, when we publish a fix for that.
also have the same issue. Unable to use the webclient after i updated my PCs to the teamviewer 12 beta.
Same problem here. Any Solution?
