How can I remove a device from the Trusted device list?
I see someone is using my licence but is probably not working for us anymore
I don't know if it's still relevant, but I found it. Log in to your account. Click to your username at the top right corner and select edit profile. There you can find the active logins and the trusted devices options. I hope it helps.
Cheers!
