When attempting to connect to my home computer from school it makes the initial connection and then works for a few moments and then as soon as I do something more than a message received on Skype which cause an update on the screen -- it will just freeze. I'm able to still send keystrokes but no-matter what I do it will not un-freeze. Disconnecting and reconnecting resolves this but then it's just back to the start; a rinse and repeat process. And after a while it will just hang on initializing. Connecting outside of the school will work perfectly fine. I've attempted reinstalling both instances of TeamViewer and attempting to use Proxies/VPNs (so far only on the client). Is this a known issue and if so is there a fix and or anything I could try to resolve the problem. It is very annoying that I cannot remote desktop into my home computer. Other solutions are just not TeamViewer
