Monitor-less computer - blank screen
Hi!
I have called Teamviewer several times about the monitor-less computer problem. Support always wants to check and call me back, but I hear nothing more.
Running teamviewer host om Win 10 and monitor-less computer resoults in blank screen, and I cannot see that anything is ment to be fixed?
I saw this article, but with no help on my problem, even though the article mentions the problem. https://community.teamviewer.com/t5/Knowledge-Base/Why-do-I-only-see-a-black-screen-after-connection-establishment/ta-p/4773
For me it looks like Teamviewer don't want to acknowledge the problem, or silence it down.
For me this is a major problem as I use it to remotely controll client computers that often have no monitor attaches. Starting to use Microsoft Remote Desktop again as in old days.
If someone have a solution or alternative software, please respond.
If someone have same problem, please comment on this tread.
Hi rosnorre
Thanks for your post and I apologise that you did not get the answer over the phone.
Officially, we don't support headless systems sorry. If you disconnect or turn off the monitor, this can cause your GPU to stop producing an image which will result in a black screen as there is nothing for TeamViewer to capture.
We are very aware of this which is why it is listed in the article you mentioned. However this is a limitation, not a bug.
If you do not have a screen attached, you could try using a dummy plug that simulates a monitor. This will make the system produce an output stopping the black screen.
-Scotty
Senior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?0 -
It doesn't work on servers and things like that. To use it I have to RDP into the Server, then x out and log in with TV. Kind of defeats the point of TV tho. The only use I've found for TV is for clients who need support occasionally on their home or laptops or while traveling etc.
I use Teamviewer 11 on headless systems all the time. However, I occasionally find that a pc or two in the field that don't play nice if somebody powers their screen down.
Condsidering what we pay...this "feature" or limitiation should be fixed!!!
hey man so i know im super late but what they are trying to say is to get an hdmi with an integrated GPU so it can trick you pc to thinking its connected to an active display when its not. basically you need a beefed HDMI cable. i personally have always been using this one and it still works for me to this day.
https://www.amazon.com/gp/product/B004S4R5CK/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
For all other interested in this topic .
- Did you try to install "TV Monitor Driver" ?
- You could also remove Desired GFX Driver from the system and use standard MS Default GFX Driver.
- Or even try to install and estabilish "TV VPN" and then log to remote computer with MS RDP over "TV VPN"
- Or try to switch few times between this 3 icons/settings.
I hope it will help you to solve your's issue.
mLipok , AutoIt MVP0 -
So. Use case, I have 15 computers on my desk to set-up, fairly add-hoc. I install team viewer on each so I can install required applications, I need to move the monitor to each PC before I can control via TV ?
Another use case, I have 3-4 RD Gateway PC's sitting in a rack in case all machines are in use, they now need a monitor on each (or a dummy connector - which when I have tested is very unreliable) before I can login to support them ??
Not sure this is a step in the right direction Team Viewer designers, can you maybe share the thought process for the change so we can understand where you are coming from ??
For anyone experiencing this issue, what worked for me was switching between the bandwidth settings. I moved it from Auto select to Optimise speed and the display rendered correctly. You sometimes have to switch back and forth a few times.
I think the guys at TeamViewer calling this a "Limitation, not a bug" is nonsense. It worked in previous versions, and it still works in 15+ when you fudge the settings so it is most definitely a bug and has absolutely nothing to do with the graphics card not sending output, and as a developer I find this explanation embarrassingly inept. Frankly, it's just lazy support.
Note, I haven't had to connect an adapter at all to get the display working, so their explanation makes no sense.
Do better TeamViewer.
2 -
In my case (switching between optimization settings) I check this problem on 2 different third party solutions, the same problems occurs. As far as I know this is related to Windows Graphic system.
If it is the case, Why can Windows Remote Desktop grab images without any problem when monitor is turned off?
It is not a problem... you ust need to uncheck option "hide wallpaper" I know it is strange, but it works :D
2 -
Peeeto Thank you so much. That was a great resolution.
Hey folks, I stumbled on one solution that worked for me anyway. I have an adapter that plugs into HDMI, and it's kind of an octopus cable that plugs into USB too to get power, and then converts to female DisplayPort. Just plugging in that adapter, which I guess is active in some way, fools the video in to acting like normal. It was just some cheapy adapter off a web site, nothing special. Might work for some of you. Of course that's not as good as a solution that needs no hardware at all, but helps in my application.
Update. My video adapter cable fix didn't continue to work. After power cycle back to the problem. Also tried the "blue" hdmi-dvi cable suggested by another. Didn't work either. I did find I have to constantly check/uncheck hide wallpaper to get things to show. In 640 x 480. Something asking for permission? screen goes black, click wallpaper. Gave it permission now screen black again, click wallpaper.
Of course in situations where you're inside or can forward a port and try MS RDP you can get any resolution that matches the station you're remoting from. So it is doable.
**Third Party Product**(hate to mention a competitor but necessary here) offers an optional video driver that creates an extra virtual display. So for a headless system, 1 display. Only goes to 1028 x 720 but better than nothing or 640x480. If they can do it teamviewer can do it.
Oh, the link about that optional driver
