I have had this issue for some while and been forturtnate that I have had someone at home to re-start the pc I connect to, while I'm away. I have come up with a solution that has worked for me ca 8 times consecutively. I set my pc to wake up with scheduled tasks. After waking the pc, I run a script to kill the teamviewer processes using a scheduled task. Some of the processes re-start, so I kill them a number of times. Then I restart teamviewer, again using a scheduled task. The 1st time I run teamviewer, I set the properties of the scheduled task to stop the running instance if the process is already running. I then set it to start teamviewer again. Not sure if that step is required, but my pc has allowed me to re-connect successfully each time since.
