Needing to install software that requires a restart. How can I set up Teamviewer to start up and still connect with the same ID and Password?
If you set up unattended access you will be able to reconnect after the system restarts. When you tell the client to restart you should receive a popup that ask Wait for Client? reply yes or wait can't remember which appears.
