I am using TV to control a remote ubuntu machine that is not connected to a physical monitor. In order to get decent resolution, I have ocnfigured a "virtual" display with HD resolution, which works great. TV allows me to scale the display of the headless linux desktop up to 1920x1080 on my mac. Huzzah!
Unfortunately, the little minimized TeamViewer indicator ("TV isn't surveillance software") can't be moved out of the way over to the edge of the screen. It is constrained to only be located within the bounds of the "physical" monitor (there isn't one). Sadly, the intel graphics in the linux box thinks the nonexistent "physical" monitor is 1024x768, so the little floating TV indicator is right in the middle of my work, always.
Can I somehow force TV to "see" that it's serving a display that is 4x bigger than the nonexistent physical monitor it sees in the video driver of the linux box?
Thanks for any advice!
Scott
