I have a PC with TeamViewer to which I connect to manage a network.
This PC is in the LAN, so behind a firewall.
If the Firewall is blocked, I can not connect to TeamViewer.
The PC has two network cards and I thought to connect one of these to the router, then outside the LAN.
The attached image can clarify the connections.
The problem is that I do not think this is possible. With two NIC TeamViewer only allows connection from the LAN.
How can I do?
Thanks in advance for suggestions.
