Teamview protable is running in limited demostration mode. Please sign in to your licensed teamviewr account in the computer & contacts list to unlock all teamviewer portable features.
I can't. Please help
Dear @cugc,
Thank you for your message. If you have a Premium or Corporate license, you are able to sign in with a licensed TeamViewer account. Just with a Business license, it is not possible to license TeamViewer portable.
The adding of the license key in the .ini is no longer possible. here you will find a detailed description:Getting started with TeamViewer portable
If you have any further questions, please do not hesitate to contact us again
Best,Natascha
In version 13 it was possible to add the license key to the teamviewer.ini file to get Teamviewer Portable licensed. If I knew this I would not have updated to v 14.
We use the portable version for a few users in our Citrix setup. I dont want to install the full teamviewer in our environment just because of that.
Hi guys,
Thank you for your posts.
The license activation with a Business license is not possible with TeamViewer portable. It just fits for devices with the TV software installed, because it needs a service that is running in the background. So, please install the TeamViewer full version to activate the license. Depending on the version, you are able to license between 1 and 3 devices.
For further questions, please do not hesitate to contact us again
Hi Natascha,
Yes, I have a business license. (over $500/yr) I also see that many others are having this same issue, just by searching the web with: “TeamViewer Portable is running in limited demonstration mode………
Rick
Dear @rickac,
Thank you for your post. Do you have a licensed TeamViewer account?If yes, why are you not able to login into the Computer & Contacts list? Do you receive any error message?
