Hi-
I just installed TeamViewer 13 on a PC running Windows XP. XP is needed to run an OEM software package.
Anyway, the forums suggest TV-13 is the perferred version to run with XP.
When I try to start TV, I get a dialog box that says:
TeamViewer Entry Point Not Found:
The procedure entry point GetLogicalPRocessorInformation could not be located in the dynamic link library Kernel32.dll.
Any suggestions?
Thank you,
Gary
