TeamViewer 14 host will not start minimized
Hi. I have installed a new digital signage PC with TW host 14. The machine are windows 10 pro x64 v.1809. Normally all other host "windows" automatically launches to the tray on other computers but on this specific computer it will not. This "window" will dissappear when you press Ok, but since this computer are automatically rebooted several days a week, it will pop up again after every reboot and you then have to login and press ok to make it dissappear. Any suggestions?
I have tryed to google around trying to find a registry setting that for example prevents this windows to pop up after reboot. Does anyone know if there are an registry setting that i can use or does anyone have other solutions to this issue?
Update : Problem solved.
Found out that this computer was getting an internet connection very slowly, and thats why the Teamviewer windows did appear. When connecting the same computer to a broadband router the network is present immediatly and Teamviewer window doesn`t pop up anymore.
