Teamviewer not starting on Raspberry Pi
I am at a complete standstill on this set of errors. The startup script is failing:
[email protected]:/opt/teamviewer/tv_bin/script $ uname -a
Linux raspberrypi 4.9.20+ #985 Mon Apr 3 10:19:25 BST 2017 armv6l GNU/Linux
[email protected]:/opt/teamviewer/tv_bin/script $ cat /etc/debian_version
8.0
[email protected]:/opt/teamviewer/tv_bin/script $ teamviewer
Init...
Checking setup...
Launching TeamViewer ...
Starting network process (no daemon)
/opt/teamviewer/tv_bin/script/tvw_exec: line 40: 1046 Illegal instruction "$TV_BIN_DIR/teamviewerd" -n -f
Network process already started (or error)
Launching TeamViewer GUI ...
Illegal instruction
DanielStm Posts: 224 Staff
Hi QBQ_RPi,
the illegal instruction thing makes me wonder if you managed to install the normal TeamViewer package, which is Wine-based and of course only meant to be installed on Intel machines.
So, using the host package is the right way to go! Make sure to pick the arm download (although the installer should make it hard for you to install the wrong package). Have a look here: Linux Host downloads
EDIT: Actually, now I spotted it: You tried to install on a first-gen Raspberry Pi, but you need a Pi 2 or Pi 3. The TeamViewer package required the armv7 instruction set. Also, the performance on a first-gen Pi would be pretty bad...
P.S.: You don't need to go to a certain directory to run the teamviewer command!
Linux Developer5
Due to the lack of any help with this problem, I have now purchased a new RPi and am trying to run the Host version. See another posting for problems with lack of persistent ID and password with this new solution. At least the host version installs and runs (once per boot session, anyway).
I'm seeing this behavior on a Pi Zero, as well.
Would be nice if the Pi Zero will be supported as well.
yes would be great for the pi zero to be supported. tried ages to get it to run. it installs fine just wont run
