I have two accounts. I use one commercially and the other one for free. On the account for free use - education disconnects me every 2 minutes. Does everybody have that?
Hello @szzs
If you want to reset your device that has been flagged as commercial, please use the following link: Reset your TeamViewer ID now!
As long as you are using the other device only for private use, you souldn't have any issue.
@JeanK wrote: Hello @szzsThank you for your message.This is indeed something that might cause problems.TeamViewer does not support double use (private and corporate use).This means, if on a device "X" you are using your commercial license, it will be flagged as such in our database. Therefore, if you are using your free account on this ID, your free account will also be flagged as being a professional use.There is, unfortunately, no way to prevent this.The only solution is to use your free account only on devices where you do not log in with your commercial license.I thank you in advance for your understanding.Cheers,Jean
Cheers,
I wrote an email a few days of the team to reset these settings. From now on I will use one computer for educational purposes, and then I will sit down to another computer and use it for commercial purposes.Will I get an answer from you?
See what's new at TeamViewer
