Sorry for my English
It's possible block setting of Teamviewer software? i would like to prevent some users from changing their personal password.
Hi @dmmario
Thanks for your question.
Yes - this is possible.
Please see: Password to protect your TeamViewer options
Thanks and best,
Esther
Hi @Elzer ,
Welcome, and thanks for reaching out to our Community!
For a case like yours, there're two configurations we recommend:
💡Hint: You can read more about mass deployment here.
I hope it helps! 🍀
Best, Carol
Hello
We are installing Teamviewer Host (remote) and regestering it to our corporate account as unattended access. We want to block the device user to change settings of local host software. And we want to remotely access to host device without a password. We have already create a policy at management console for removing password but we cant find the policy that blocks the device user to change the settings.
Can you suggest something for that?
Hi again @dmmario
No, this is not possible.
Every user has always the possibility to end a session as they desire and TeamViewer is not designed to run in stealth mode either.
Thanks for your Reply.
Can I ask another question?
Is it possible to lock the exit button from the program ?. I would like to ensure that users cannot close the software.
