New installations is not added to management Console
olefisk
olefisk Posts: 2 ✭✭
Teamviewer 14
New clients are installed via MSI-package, Registry-file and  the Command:
TeamViewer_Host.msi" CUSTOMCONFIGID=xxxxxxxx IMPORTREGFILE=1 ALLUSERS=1 REBOOT=ReallySuppress /L*v %LocalPackageDir%\setup.log
In the Management-Console the Value for "Automatically Add Computer to Group" is set.
But the Clients don not show up in the management-Console.
Did work fine in Teamviewer 12, but can't get it to work with the changes made in Teamviewer 14
  • olefisk
    olefisk Posts: 2 ✭✭
    Hi Jean
    Thanks for the detailed information.
    Sorry for the late reply, but I did have to do a lot of Testing.
    I'm using the Application "EasyInstall" for deploying Teamviewer, and It seems that it causes some Issues using "Assignmentoptions", so I ended up with the following parameters which works:
    msiexec.exe /i "path\TeamViewer_Host.msi" /qn IMPORTREGFILE=1 CUSTOMCONFIGID=<YOURCONFIGID> APITOKEN=<YOURAPITOKEN>
     In the Teamivewer management-Console it is configured that new clients are places in a specific Group.
    Best regards
    Ole Fisker
    JeanK Posts: 6,893 Community Manager 🌍
    Hello @olefisk
    No worries - I totally understand. ?
    It is great to hear that you have now found the correct line to deploy your TeamViewer clients.
    It is also interesting that the ASSIGNMENTSOPTIONS can cause problems with some deployment apps - we will forward this internally.
    We wish you a good rest of the week and hope to see you soon again on the Community.
    Cheers,
