I am controlling a windows pc remotely using an Android phone. I need to be able to left-click on a button and hold it down for a while while an action takes place. Is there any way this can be done?
Many thanks,
Neil.
I found the answer by accident. To hold a button down, place the cursor over it, tap it twice but hold the second tap. Then drag slightly, the button activates and holds until you take your finger off. HTH someone!
I am also having this issue, when working remotely any click that I make on a mouse it will always hold the click until I can click slowly to release the click. Very frustrating and difficult to use.
Any way to turn off the click hold?
@Coastliner This is the problem I'm having! When I am clicking around and dragging a lot, using 3D software, often when I let go, it thinks I'm still dragging. Its this feature, where the second click holds even when I let go. Is there a way to turn this feature off?
