I am connected to a remote PC. Teamviewer starts with Windows and I have unattended access. Will it be possible that my collegues joins the same PC in order to help me on the target PC? In other words: 2 Connections at the same time.
Asger
Hi Asger,
Yes you just have to share the Teamviewer ID to your collegues.If you set a personal Password to the remote PC your collegues can use that too, you could also set a randomized Password. To set a randomized Passwort go to the Settings -> Security -> Random Password.
Hope this will help you.
Kyzeria
Thank you very much.
Yes - worked perfect with 2 connections.
@Kyzeria wrote: Hi Asger,Yes you just have to share the Teamviewer ID to your collegues.If you set a personal Password to the remote PC your collegues can use that too, you could also set a randomized Password. To set a randomized Passwort go to the Settings -> Security -> Random Password.Hope this will help you.Kyzeria
