HELP
Hello, I opened the teamviewer without installing it and released "remote access" to an acquaintance.
I suspect that he copied files from my machine and wanted to see all the files that were copied from my computer.
How to check the history of files transferred by teawviewer?
Hello @K4M4R40
Thank you for your message and welcome in the TeamViewer Community! ?
There are log files generated on each TeamViewer installation which might contain information on whether or not files were transferred.
However, if you only run TeamViewer without installing it, no logs were generated during the transfers, therefore you can't have any history of these transfers.
