When i listen to music connected to another computer the sound comes out both devices. how can i control the sound so that it ony comes out on the destination computer. thank you
Please, open your local TeamViewer client.
Where is "Extras" located?I don't see "Extras"
Extra -> Options
Where do I find "Options"? FYI: I have the free version so I do not have access to all areas of the Teamviewer service areas, I do not know if that is why I do not see "Options".
Hi @susieqk,
maybe this:
(you need to disable that check)
can you share your solution? I have the same issue. I don't want to hear destination computer's music when connected. Thanks!
found the settings! thank you anyways
