Can't Connect to Any Partner/IDs on Mac
I am using an updated Mac laptop and an unable to connect to any of my Partner ID's when using the Chrome browser and Firefox browser (both updated). When I attempt to connect from my iPhone or iPad they both connect. That tells me it is most likely an issue with my Mac.
Any idea what I can do to fix this issue?
  • sekzman
    sekzman Posts: 3
    How do I get someone to respond?
    It has been 2 weeks and I have received 0 responses
  • Scotty
    Hi sekzman,
    Can you provide any more information that can help the community assist you? At the moment, all we know is that you have a connection problem.
    Do you get any error messages? At what point does the connection fail? Can you send a screenshot? (remove identifying information)
    It sounds like you are trying to make a connection from your browser. TeamViewer software is designed mainly to connect from the software, have you tried connecting from the application?
    -Scotty
    Senior Moderator
  • sekzman
    sekzman Posts: 3
    Scotty,
    Thanks for the response :)
    Screenshot attached. Yes, I was trying to connect from my Chrome browser. When I click on any of the blue Connect buttons, nothing happens. This is only a problem when connecting from my Mac and not from my iPad or iPhone. Do you know how I can correct the issue or is it something Teamviewer needs to resolve?
    Eric
