Team Viewer for Ubuntu Server 18.04.4 running on Raspberry Pi
I'm running Ubuntu Server 18.04.4 LTS (64bit) for Raspberry Pi from https://ubuntu.com/download/raspberry-pi on a Raspberry Pi 3 Model B+ (https://ubuntu.com/download/raspberry-pi/thank-you?version=18.04.4&architecture=arm64+raspi3). I downloaded Team Viewer Host for Raspberry Pi from https://www.teamviewer.com/en/download/raspberry-pi/ . Unfortunatelly I the installation failed.
$ sudo dpkg -i ./teamviewer-host_armhf.deb
dpkg: error processing archive ./teamviewer-host_armhf.deb (--install):
package architecture (armhf) does not match system (arm64)
Errors were encountered while processing:
Seems like Team Viewer for Raspberry Pi is for armhf architecture only. I need the package for either amd64 or aarch64 instead.
$ uname -a
Linux ubuntu 5.3.0-1017-raspi2 #19~18.04.1-Ubuntu SMP Fri Jan 17 11:14:07 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
Is there a package built for my needs already?
  • DomLan
    DomLan Posts: 490 Star
    Hi @fkromer,
    try standard Ubuntu (Debian) package
    Regards.
    Domenico Langone
    MCSD: App Builder
  • fkromer
    fkromer Posts: 4
    Hi @DomLan ,
    I already tried. Unfortunatelly the installation fails as well:
    $ sudo dpkg -i ./teamviewer_amd64.deb
    dpkg: error processing archive ./teamviewer_amd64.deb (--install):
    package architecture (amd64) does not match system (arm64)
  • DomLan
    Hi @fkromer
    I do some verification and update you. Actually for the PI distribution it indicates v2 or higher
    What kind of PI do you have?
    Domenico Langone
    MCSD: App Builder
  • DomLan
    Hi @fkromer,
    here there is a specific section for installing on Linux device: Older 64-bit DEB-systems without Multiarch (Ubuntu 12.03, Debian 6 and below) - and a mention for your wrong architecture message
    Try it.
    Let me know!
    Domenico Langone
    MCSD: App Builder
  • fkromer
    fkromer Posts: 4
    Hi @DomLan ,
    I've tried something mentioned in some other posts. However it did not work:
    $ sudo dpkg --add-architecture armhf
    Selecting previously unselected package teamviewer-host:armhf.
    (Reading database ... 104510 files and directories currently installed.)
    Preparing to unpack ./teamviewer-host_armhf.deb ...
    Unpacking teamviewer-host:armhf (15.3.2682) ...
    dpkg: dependency problems prevent configuration of teamviewer-host:armhf:
    teamviewer-host:armhf depends on libc6 (>= 2.17).
    teamviewer-host:armhf depends on libdbus-1-3.
    teamviewer-host:armhf depends on libqt5gui5 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on libqt5widgets5 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on libqt5qml5 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on libqt5quick5 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on libqt5dbus5 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on libqt5webkit5 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on libqt5x11extras5 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on qml-module-qtquick2 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on qml-module-qtquick-controls (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on qml-module-qtquick-dialogs (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on qml-module-qtquick-window2 (>= 5.5) | qt56-teamviewer.
    teamviewer-host:armhf depends on qml-module-qtquick-layouts (>= 5.5) | qt56-teamviewer.
    dpkg: error processing package teamviewer-host:armhf (--install):
    dependency problems - leaving unconfigured
    Processing triggers for mime-support (3.60ubuntu1) ...
    $ sudo apt --fix-broken install
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Correcting dependencies... Done
    The following packages were automatically installed and are no longer required:
    golang-docker-credential-helpers libpython-stdlib libpython2.7-minimal
    libpython2.7-stdlib libsecret-1-0 libsecret-common python python-asn1crypto
    python-backports.ssl-match-hostname python-cached-property python-certifi
    python-cffi-backend python-chardet python-cryptography python-docker
    python-dockerpty python-dockerpycreds python-docopt python-enum34
    python-funcsigs python-functools32 python-idna python-ipaddress
    python-jsonschema python-minimal python-mock python-openssl python-pbr
    python-pkg-resources python-requests python-six python-texttable
    python-urllib3 python-websocket python-yaml python2.7 python2.7-minimal
    Use 'sudo apt autoremove' to remove them.
    The following packages will be REMOVED:
    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
    1 not fully installed or removed.
    After this operation, 55.2 MB disk space will be freed.
    Do you want to continue? [Y/n] Y
    (Reading database ... 104630 files and directories currently installed.)
    Removing teamviewer-host:armhf (15.3.2682) ...
    Obviously the package was not installed correctly and was removed:
  • jtf
    jtf Posts: 1
    $ wget https://download.teamviewer.com/download/linux/teamviewer-host_armhf.deb
    $ dpkg --add-architecture armhf
    $ apt-get update
    $ dpkg -i teamviewer-host_armhf.deb
    $ apt-get --fix-broken install
    It seems ok but
    $ teamviewer
    Init...
    Error: CheckCPU: unknown architecture 'aarch64'
  • Tuvar
    Tuvar Posts: 1
    Did you ever resolve this? I have the same issue, but on a Pi 4 and Ubuntu 20.04
  • nishad1092
    nishad1092 Posts: 3 ✭✭
    hI @themreza
    This link looked promising, but after installation, the TV didnt open..
    any idea when TV will be released for jetson xavier arch armv8?
Howdy, Stranger!
