Teamviewer for raspberry headless setup problem
Hello, i installed the teamviewer for raspberry on my raspberry pi 3 and it works great and all but i wanted to set up the headless mode via the console command
sudo teamviewer setup
and it gives me connectivity issues everytime i enter my email and password
how can i fix this issue?
Dear Kezbar,
Thank you for your correspondence thus far.
We got some news from our developers, and this is, unfortunately, a known problem in the current version. Our developers are already working on a solution, and the issue will soon be solved.
We are sorry for the inconvenience.
If you have any further questions, please feel free to contact us.
Best Regards,
Christian
Did my reply answer your question? Accept it as a solution to help others, Thanks.0 -
Dear Kezbar,
The TeamViewer setup command helps you to add your device to your computers and contacts with EasyAccess. However, you may be able to use your system in headless mode by following this workaround.
#get teamviewer id
teamviewer info
#set a password
sudo teamviewer passwd [password]After running those commands, you may add your device to your computers and contacts list.
Hope that solution works for you.
Christian
Did my reply answer your question? Accept it as a solution to help others, Thanks.2 -
i have the same problem , working on a raspberry pi 3 only with ssh
no monitor no keyboard attached to RASPI
password is set and i know the ID
Version of TV is TeamViewer 12.0.78433 (deb)
i could see the RASPi from Windwos, but if i connect i am getting "Authentification denied"
both pc are on same private network
i have reduced complexity of password , but it is not working
2017/06/04 17:05:26.986 3240 1953494096 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 0, Errorcode=11
2017/06/04 17:05:27.000 3240 1996013568 DX0! XSM: No X Session Management for current session available (yet)
2017/06/04 17:05:27.087 3240 1953494096 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 1, Errorcode=11
2017/06/04 17:05:27.188 3240 1980757072 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 2
2017/06/04 17:05:27.202 3240 1904211024 DX0 CLoginServer::CheckIfConnectionIsAllowed()
2017/06/04 17:05:27.290 3240 1972368464 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 3
2017/06/04 17:05:27.391 3240 1953494096 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 4, Errorcode=11
2017/06/04 17:05:27.492 3240 1980757072 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 5
2017/06/04 17:05:27.595 3240 1972368464 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 6
2017/06/04 17:05:27.696 3240 1980757072 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 7
2017/06/04 17:05:27.798 3240 1953494096 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 8, Errorcode=11
2017/06/04 17:05:27.900 3240 1972368464 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 9
2017/06/04 17:05:28.001 3240 1961882704 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 10, Errorcode=11
2017/06/04 17:05:29.015 3240 1972368464 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 20
2017/06/04 17:05:30.041 3240 1972368464 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 30
2017/06/04 17:05:31.054 3240 1972368464 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 40
2017/06/04 17:05:32.068 3240 1980757072 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 50, Errorcode=11
2017/06/04 17:05:33.082 3240 1961882704 DX0!! GuiWindowCheckLin::CheckForValidGUIWindows: n(0) , m(0) count 60, Errorcode=11
2017/06/04 17:05:33.203 3240 1904211024 DX0!! CLoginServer::CheckIfConnectionIsAllowed: GUI check timed out or cancelled
2017/06/04 17:05:33.203 3240 1904211024 DX0!! CLoginServer::CheckIfConnectionIsAllowed: Incoming connection from 101518111 denied, because TeamViewer is not visibledo i have to accept licsence before ??
Cu
Chris
Dear Blacky,
Yes, you need to accept the license agreement.
To make sure you already accept use the following command
grep -i eula /opt/teamviewer/config/global.conf
To accept license agreement you may run the following command on a CLI session
Hope this solution works for you.
Christian
Okay. I've done every step. I pressed 'y' to EULA. Then TeamViewer prompted to enter e-mail/name, okay. Then - password. But when I've done - it was: sign in failed (unknown reason). What I am doing wrong?0
I've got the same problem with setup. It makes me mad !
Did you find a solution ?
Steve
