415 Unsupported Media Type
I exported my Monitis uptime monitors and imported them to TV-WM but all of them are failing with error code: 415 Unsupported Media Type
What I do is that I do an HTTP POST to a SOAP UI end check the result with the advanced "check for string" option.
Any clue what I am doing wrong? Or how I can debug this to a working solution?
Hi ID_Conn,
Thanks for using Web Monitoring,
Most probably you are using in Monitis one of the advanced settings for Uptime monitors that are not yet supported in Web Monitoring. According to 415 Status Code, and as we support content matching or check for string functionality this can be a Response Header feature.
Sorry for the inconvenience.
Regadrs
Product Owner, Remote Management services0 -
Indeed in Monitis I am using a request header, content-type = application/soap+xml; charset=utf-8
Any clue when this functionality is available in TV-WM?
Pieter0
