Connection to previous version - Only with license?
Hello..
I have a family member running MacOS Yosemite, their OS cant be upgrade any further do to the old hardware (its a MBP from 2009), and hence they are stuck on TV v.13 as per TVs own documentation..
The latest version installs but wont start on the machine..
I have a new Macbook Air M1, with the latest version of TV installed, now I cant remote their computer. I understand thats due to some implemented limitations in TV.
How do I remote the machine? Do I need a license? Do we both need licenses?? (I remote her computer, she dosent remote mine)..
Searching the forum reveals that this affects loads of people, so a clarification from TV on how to do this would be very much appreciated! I cannot believe that this problem cant be solved in some way?
OBS! and no, her buying a newer machine is not an option atm.
Hello @RJBoxer,
The usage of the free version is only possible with the latest version of TeamViewer on both ends of the connection.
However, you can connect to older versions with a TeamViewer license.
In this use case, only you will need a license. Not the remote user.
