You can't log in if you run the teamviewer on your phone from 2021. I'm asked to check the internet connection, but the internet is working well. I deleted the application and re-installed it, but the same problem is repeated. The login or connection from my laptop is working well without any problems, but there is a problem if I run it on my phone.
