frequently getting this message when trying to access my iMac remotely from my MBAir - any advice would be greatly appreciated!
Thanks for the tip - I've tried that multiple times with no success =(
It seems that if the Mac I'm trying to access has gone asleep - then I can't access it
I have enabled "Wake for Network Access" in the power settings - but again no luck
I also found this doc online https://dl.teamviewer.com/docs/en/TeamViewer-Manual-Wake-on-LAN-en.pdf but it appears to be dated as some of the references are no longer available
Thanks in advance for any suggestions you might have
Hello @TWackel,
This message indicates that TeamViewer lost the connection to our master server.
I recommend you to restart TeamViewer on the affected devices.
