Bad text formatting on Teamviewer
Hello. I am using Kubuntu 20.04 stable and there is a problem with Teamviewer. I have tried to reinstall it, purge and install again, install from different packages, and etc. Every time I have got the same problem: Fonts size is too large and all the formatting of the window is looking really weird. Here attached a screenshot
Is there any way to fix it? Thanks
Also I have noticed that there are some "graphics artifacts" while connected to another PC (there are some random lines on the display)
hi,
i had a similar problem.
My desktop is a 4k display, and i have set in the KDE 'System Settings' - 'Display and Monitor' the 'Global scale' to 150%
which leads to an environment variable QT_SCREEN_SCALE_FACTORS reflecting a factor of 1.5
by overriding the factor to 1.0 the TV UI gets usable again.
give it a try.
br
Roland
It works. Thank you
1
