Bad text formatting on Teamviewer
Wovich
Wovich Posts: 1
edited March 2021 in Linux only
Hello. I am using Kubuntu 20.04 stable and there is a problem with Teamviewer. I have tried to reinstall it, purge and install again, install from different packages, and etc. Every time I have got the same problem: Fonts size is too large and all the formatting of the window is looking really weird. Here attached a screenshot
Is there any way to fix it? Thanks
Also I have noticed that there are some "graphics artifacts" while connected to another PC (there are some random lines on the display)
