Operating system: Linux
Version: 15.16.8
Release date: 2021-03-23
Finally!!! I can hear the sound! Thank you very much for this feature. Hope you will align Linux version to Windows sooner then I become old )
when we connect to version 15.16.8 in remote control, the connection freezes after a few seconds. Teamviewer generates a crash file. We went back to version 15.15.5 which does not have this problem.
Uninstalling the .deb package throws an error:
The following packages will be REMOVED:
teamviewer*
0 upgraded, 0 newly installed, 1 to remove and 62 not upgraded.
After this operation, 75.6 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 306143 files and directories currently installed.)
Removing teamviewer (15.16.8) ...
Removed /etc/systemd/system/multi-user.target.wants/teamviewerd.service.
Clearing assignments ...
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_M_construct null not valid
/var/lib/dpkg/info/teamviewer.prerm: line 41: 45328 Aborted (core dumped) $TV_BIN_DIR/teamviewerd --unmanage
done
Also, the headless command 'teamviewer setup' doesn't seem compatible with 2FA, which I always use.
Instead of asking for the 2FA code it stalls, and after a while claims
Connected
Please enter your e-mail / username: MyEmailHere
Please enter your password: PasswordAcceptedFine
Initiating sign in
There was a connectivity issue. Please check your internet connection and try again.
I had the same issue as. Luckily, my system isn't headless, so I could complete the account setup graphically.
It's broken on the Raspberry Pi .deb version. I can view the screens but have no control. Please look into it asap.
In these current times, people are relying heavily on your software. To be pushing updates out without thoroughly testing (again) is not ideal.
another try:
teamviewer-host 15.16.8 (RPM) on CentOS7
running
# teamviewer passwd secret
aborts with:
/opt/teamviewer/tv_bin/script/tvw_extra: line 77: 3677 Aborted "$TV_BIN_DIR/teamviewerd" --passwd "$pwd"
unknown response
CentOS 7 - remote box - accessed using SSH
[log files removed per Community Guidelines]
Will the gray screen part over the audio controls be addressed? This is a long standing issue that prevents using audio.
https://community.teamviewer.com/English/discussion/100998/blurry-parts-of-screen#latest
