Agent assign "SSL peer certificate or SSH remote key was not OK"
luke_b
luke_b Posts: 3 ✭✭
Hi
i am trying to install the Teamviewer-iot-agent on a custom device.
When i try to assign the key with the command:
teamviewer-iot-agent assign -t xxxxxx-xxxxxxxxxxxxxxxxxx -g $'My computers'
i receive
Assignment is in progress ...
Failed to assign. See the log file for details.
and the log shows
HttpClient::CreateRequest options=<none>
2021/04/24 23:45:36.074 25634 3069874192     HttpRequest::StartGet url=https://webapi.teamviewer.com/api/v1/devices?remotecontrol_id=r2029763294
2021/04/24 23:45:36.216 25634 3067101008 !! HttpRequestImpl::CurlFinished(): curl request failed: SSL peer certificate or SSH remote key was not OK (60), SSL certificate problem: unable to get local issuer certificate
2021/04/24 23:45:36.218 25634 3069874192  !! DeviceAssignmentStarter::Run: device assignment failed - WebAPI failed to perform requested action - HTTP request has failed permanently - https://webapi.teamviewer.com/api/v1/devices - SSL certificate problem: unable to get local issuer certificate, Errorcode=97
any help?
  • mircea_c
    Hi @luke_b
    At first glance is looking as a connection issue. Please have a look here for checking the open ports used by Teamviewer.
    Also check if SSL requests/handshake are not getting blocked in the firewall.
    Tech Support IoT
  • luke_b
    luke_b Posts: 3 ✭✭
    Thank you for the answer,
    i just solved it with a linux certificate upgrade, specifically "Comodo AAA Services root"
