Is there a 64 bit version
riptron
Posts: 1 ✭
Looking for a 64 bit version of TeamViewer
I had a notice that there is now a 64 bit version of Team Viewer, and was able to download it.
However, it say I must remove the 32 bit version which I purchased first.
What I cannot establish is whether or not one is permitted to install the 64 bit version using whatever credentials I had for the 32 bit one.
Does anyone know the answer?
George
Yes, you can use your credentials for both versions.
