Xiaomi Redmi Quicksupport works only one time
tkleetv
tkleetv Posts: 1
I installed quicksupport and its add-on on a Xiaomi Redmi 9T. I could connect to it successfully over the internet from a PC one time. After that, the next connection only allowed me to view the screen, and no remote control. Furthermore, viewing only should show the the screen touches but I don't get that either.
How do I make this work reliably?
Thanks.
  • Claude_53
    Claude_53 Posts: 1
    Hi, same problem on a Xiaomi Redmi Note 9 and Xiaomi Redmi Note 9S.
  • Solarwin
    Solarwin Posts: 1
    The add-on seems to allow remote control on the day you install it, but the following day it only displays the screen, as the OP said.
    I uninstall the add-on and then install it again, that seems to work for another day.
    Would be nice not to have to do that though
    Hello all,
    Once the Universal add-on is installed, it should remain as it is and not change the behaviour after a reboot.
    Did you update the firmware of your devices?
