TeamViewer is opening full screen every time my computer starts
Since a week or so TeamViewer is opening full screen every time I start my computer. Did anyone experience this also? I can't find a setting how to change this. It should only start minimized in the task bar. Like it did since 10 years.
  • GrinchStix
    GrinchStix Posts: 0
    Seeing the same behavior on my system as well and haven't found a way to disable it.
    Added a scheduled task on login to run a PowerShell script as admin with the following:
    Stop-Process -Name TeamViewer
    This will only kill the window and tray icon, but the service will still be running so it can still be connected to.
  • PSupport
    PSupport Posts: 4 ✭✭
    edited May 2021
    Hi GrinchStix,
    Thanks for your reaction. I'm not the only one apparently.
    I like your solution. I didn't think of it. However, I would like TeamViewer themselves to solve this.
    I hoped for a lot more reactions from other users, but apparently no seems to bother.
    Thanks anyway.
