Deploy Teamviewer Update for old 8.0/9.0 versions GPO install on top?
ITGUYS
Posts: 1 ✭
Does anyone know if you can deploy TeamViewer MSI over the top of the older version to update from 8.0 to 15?
We have a ton of old machines due to an old license that was in use. It looks like the auto update does not work for these. So rather than manually trying to update 50 machines and check all 100, I'm wondering if you can do remote install of MSI via GPO or Landesk and update it that way?
