Every time I start up my computer there is no audio until I switch to a real audio device that is real and exists and has a purpose. I removed the malware installer ("TeamViewer") and it's still there! Permanently!! Whose idea was this?
Hi!
There has been an update on this.
Please make sure that you have selected from the options "Send sound from this device" as shown in the picture below:
This should fix the issue.
If this does not work, please contact our support via support ticket or by calling us.
-Jesse, TeamViewer Support
"Please make sure that you have selected from the options "Send sound from this device" as shown in the picture below:"
Mac mini M1 (2020) - macOS Monterey 12.5 - TeamViewer Host 15.32.3 H (08ee49d90b1)
No such menu item!!! Please help!
For me, this does not solve the issue. It removes it, but it then reappears again soon after. I even did reboots after following the steps above and removing it. My clients are a little upset as it is screwing up their output choices.
Hi. I was struggled with this issue for months. and I just googled this solution which works !
Follow these steps:
and we select the TeamViewer Multioutput Device and click the minus as described above.
and voila :D
hope this works on your Mac too.
