Exporting a list of my Computers
Tigerpie_VS
Tigerpie_VS Posts: 1
edited June 2023 in General questions
Is it possible to export a list of all the devices contained within the "Computers & Contacts" section thorugh either the Web Managment console or The Teamviewer managment program on windows?
Cheers guys
  • Kfix
    Kfix Posts: 0
    I need to export devices that are currently enrolled in order to indentify those that have not received the policy .
    Thank you.
  • ArvidInSupport
    ArvidInSupport Posts: 3 ✭✭
    What can I export? At the moment I am limited to :
     "remotecontrol_id":
        "device_id": "
        "alias":
        "groupid":
        "online_state":
        "assigned_to":
        "teamviewer_id":"
    I would like to export more things about my devices. For example, Which version of teamviewer they are running, how long have they been online. etc.
    Indeed, the export is limited to the parameters you have mentioned.
    There are currently no further parameters available such as the TeamViewer version, how long they have been online etc...
  • ArvidInSupport
    How can I add more parameters to your code?
    I would like to add
    "supported_features (string, optional),
    last_seen (string, optional),"
    Is it possible?
    This is currently not possible.
  • RyanMaeng
    RyanMaeng Posts: 3 ✭✭
    Hi JeanK
    How to import users with a csv file on powershell ??
    Hi @RyanMaeng,
    Please find how to import the list into your Management Console in our documentation here:
  • pshute
    pshute Posts: 7 ✭✭
    The TeamViewer API method described above worked to download all our devices, but why are some of the last_seen values blank? Some of the devices concerned have been accessed recently.
  • pshute
    pshute Posts: 7 ✭✭
    edited November 2021
    When I used this method a few days ago, the header line in the dump was
    "remotecontrol_id","device_id","alias","groupid","online_state","policy_id","assigned_to","last_seen","teamviewer_id"
    Today the header line is
     "remotecontrol_id","device_id","alias","groupid","online_state","policy_id","assigned_to","supported_features","teamviewer_id"
    What happened to the last_seen column?
  • Akiho
    Akiho Posts: 1,210 Moderator
    Hi @pshute,
    Thank you for reaching out to the community
    Good questions!!
    Honestly, I'm not 100% sure about this case.
    So, I discussed the case with our technical support engineer @Scotty, and I confirmed the below details.
    Last Seen
    The last_seen value is optional and is only available if the device is assigned to the user doing the export and is currently offline. You can confirm this in the documentation here - 4.10.1
    last_seen (optional): The timestamp of the last time, the device was online. Is not returned if the device is currently online. Only available if the device is assigned to the current user.
    "Missing Column"
    It is important to note that API's do not return columns, they return responses formatted in JSON with only the values for each response. In this case, I would assume you are using PowerShell or similar that is converting this into an array, then converting that into CSV.
    The CSV conversion is making columns out of the returned data. If there was no "Last Seen" values returned, it would not make a column for this as this value would not have ever appeared in the array.
    You can see how the raw responses look in our Test Center (Note you need to add the word "Bearer" before your API token).
    Hope this answers your question!
    Please let us know if you have further questions or concerns! 🙌
    Akiho
    Japanese Community Moderator / コミュニティモデレーター
  • pshute
    pshute Posts: 7 ✭✭
    Thanks, I just used the code provided above by JeanK.
    I exported to both CSV and JSON, and I can see last_seen values in the JSON file. I think the difference is that there's no value for it in the first "row". I suspect the Export-Csv cmdlet ignores fields with names that aren't in the first row.
  • JanBorup
    JanBorup Posts: 1
    I have tried the JeanK PS script, but it fails in my PowerScript with this:
    Invoke-RestMethod : Den angivne værdi har ugyldige kontroltegn.
    Parameternavn: value
    At line:4 char:20
    + ... sResponse = Invoke-RestMethod -Uri "https://webapi.teamviewer.com/api ...
      + CategoryInfo     : NotSpecified: (:) [Invoke-RestMethod], ArgumentException
      + FullyQualifiedErrorId : System.ArgumentException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
    Export-Csv : Cannot bind argument to parameter 'InputObject' because it is null.
    At line:6 char:28
    + ... e.devices | Export-Csv -Path $csvFile -Delimiter ',' -NoTypeInformati ...
      + CategoryInfo     : InvalidData: (:) [Export-Csv], ParameterBindingValidationException
      + FullyQualifiedErrorId : ParameterArgumentValidationErrorNullNotAllowed,Microsoft.PowerShell.Commands.ExportCsvCommand
    My PowerShell version is:
    Name              Value
    PSVersion           5.1.19041.1320
    PSEdition           Desktop
    PSCompatibleVersions      {1.0, 2.0, 3.0, 4.0...}
    BuildVersion          10.0.19041.1320
    CLRVersion           4.0.30319.42000
    WSManStackVersion       3.0
    PSRemotingProtocolVersion   2.3
    SerializationVersion      1.1.0.1
    Can anyone help me here ??
  • MCHD
    MCHD Posts: 2 ✭✭
    @JeanK I don't know how old your solution is but tried it just now and I was able to dump the data I needed for our organization. Thanks!
    @MCHD thanks for reaching out!
    Could you let us know what you have exactly tried? Which data did you pull out in your operations?
  • Marcelofs1
    Marcelofs1 Posts: 4 ✭✭
    Hello @JeanK
    I've been struggling for a while trying to use an API to get GROUPS information. I have managed to get the overall users script working fine and I am able to get a list of all users, however when I try to GET groups and their associated users I got some errors I couldn't find the reason.
    The USERS scripts works fine and it is like that
    $headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
    $headers.Add("Authorization", "Bearer USER TOKEN Created")
    $response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/users?full_list=true' -Method 'GET' -Headers $headers
    $response.users | Select-Object -Property "name","email","last_access_date","active" | Export-Csv "C:\Users\MyUser\TV-USERSList.csv"
    $response | ConvertTo-Json
    However when I try to run similar script for GROUPS users
    $headers.Add("Authorization", "Bearer OTHER Token created for GROUPS")
    $response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/groups?name=TST' -Method 'GET' -Headers $headers
    $response.groups | Select-Object -Property "id", "name", "shared_with" | Export-Csv "C:\Users\MyUser\TV-groups.csv"
    I got a BLANK .csv file however on the PowerShell screen I got the whole USERS listing even using a token created for GROUP management. Also, when running I got this error message
    Invoke-RestMethod : {"error":"invalid_token","error_description":"Access token is of wrong type. You need a UserToken to call this function.","error_code":2}
    At line:3 char:13
    + $response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/g ...
      + CategoryInfo     : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-RestMethod], WebException
      + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
    I have also tried to run using other tokens generated without success. I also tried running from the web interface from TeamViewer at https://webapi.teamviewer.com/api/v1/docs/index#!/Group32management/Groups_Get_0 without success.
    I am quite sure I am missing something very basic on the groups query but I just can't see what it is.
  • Marcelofs1
    Hello anyone. No response on that? I really couldn't get this listing.
    Hello @Marcelofs1,
    Welcome to the TeamViewer Community and sorry that no one got back to you earlier.
    I asked our API master Guru and according to the error message,
    it could be that the token you are using is wrong.
    You need to make sure you use a user token and not a company token.
    You can create a user token by clicking your user nameEdit profileApps Create script token
    Looking forward to hearing from your tests!
    /JeanK
  • Marcelofs1
    Thank you.
    Yes I am using the correct token. I have no idea why such message occurs. I have even created a new token for GROUP management with same results.
    I also tested on https://webapi.teamviewer.com/api/v1/docs/index#!/Group32management/Groups_Get_0 as it "generates" the command so I prevent the possibility of typos or something without success.
    I thought of any typos or even some weird characters and double checked spelling. I have created a new token for Group Management but I am still getting the error below
    Well, the function I am calling is GROUP on this line
    $response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/groups?name=MYGROUP' -Method 'GET' -Headers $headers
    Just for testing, I also used the USER token with the same string and got exactly the same error message.
    Odd enough, when I run it for collecting the user list, it work perfect.
    Once again, thank you for your time.
    Marcelo
  • Marcelofs1
    Hello @JeanK
    I am now totally puzzled. This script, using a token created for GROUP MANAGEMENT got me output
    PS H:\> $headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
    $headers.Add("Authorization", "Bearer XXXXXXXXXXXXXXXXX")
    $response = Invoke-RestMethod 'https://webapi.teamviewer.com/api/v1/groups?' -Method 'GET' -Headers $headers
    $response.groups | Select-Object -Property "id", "name", "shared_with" | Export-Csv "C:\Users\local folder\TV-groups.csv"
    At line:3 char:13
      "users": [
               "id": "yyyyyyyyyy",
               "name": "Kkkkk Jjjjjjj",
               "permissions": "ShareOwnGroups,ManageUsers,EditFullProfile,ViewAllConnections,ViewOwnConnections,EditConnections,DeleteConnections,ManagePolicies,AssignPolicies,AcknowledgeAllAlerts,AcknowledgeOwnAlerts,ViewAllAssets,ViewOwnAssets,Edit
    AllCustomModuleConfigs,EditOwnCustomModuleConfigs,ManageSettingPolicies,AssignSettingPolicies,ManageAntiMalwarePolicies,AssignAntiMalwarePolicies,AcknowledgeAllAntiMalwareThreats,AcknowledgeOwnAntiMalwareThreats,TrustedDeviceManagement,ManageBackupPolicies,A
    ssignBackupPolicies,BackupViewAndAckOwnAlerts,AllowPasswordChange",
               "active": true,
               "log_sessions": true,
               "show_comment_window": true,
               "email": "abcde.fghijk@company.com",
               "last_access_date": "2022-06-24T16:50:27Z",
               "activated_license_id": "license#",
               "activated_license_name": "Tensor Basic"
    I got surprised as the GET function is for GROUP and I got the entire listing of users and the output file was blank (that makes sense as I am trying to get the Group listing).
    Not sure if this does not also indicates some kind of security breach. I was not supposed to get a user list with such token right?
    Marcelo
    Hello @Marcelofs1,
    Thank you for getting back with the info.
    The best way to resolve your issue would be to create a support ticket.
    Our engineers will be happy to help you further.
    You can create a ticket here: 📩 Create support ticket
    Sorry that I cannot help you more here, but my API knowledge is very basic.
    /JeanK
  • mrcllnbrg
    mrcllnbrg Posts: 1
    Is there a way to do this on a Mac?
    Hello @mrcllnbrg,
    There is no operating system restriction when using the API.
    So yes, it's possible to do it on macOS.
    /JeanK
  • ITmatt
    ITmatt Posts: 0
    2023 and still no way to export a device list, I find this sad and pathetic. **bleep** has no issues exporting a device list.
  • PeterNeville
    PeterNeville Posts: 1
    Turns out I can't include links in my posts.
    If you are trying to get a list of members of a Device Group rather than a Group
    Change the -URI so it ends /v1/managed/groups which will list the Device Groups and their IDs.
    Then change it to /v1/managed/groups/<GroupID>/devices to list the members
  • AJ86
    AJ86 Posts: 1
    How to find device Management, through script
  • pshute
    pshute Posts: 7 ✭✭
    Could somebody please post new instructions for creating the token for exporting a device list? The interface has changed, and no longer matches the instructions above. There is no "Computers and Contacts" section in the list of permissions. Do we just use the Contacts section now?
    Also, when I use the token I generated a year or so ago using the instructions above, I don't get a full list of computers. I think the migrated devices are missing.
  • tvapips
    tvapips Posts: 4 ✭✭
    Much easier, just do a "Get-TeamViewerManagedDevice" or "Get-TeamViewerDevice".
    Add-TeamViewerAssignment
    Add-TeamViewerCustomization
    Add-TeamViewerManagedDevice
    Add-TeamViewerManager
    Add-TeamViewerSsoExclusion
    Add-TeamViewerUserGroupMember
    Add-TeamViewerUserGroupToRole
    Add-TeamViewerUserToRole
    Connect-TeamViewerApi
    Disconnect-TeamViewerApi
    Export-TeamViewerSystemInformation
    Get-TeamViewerAccount
    Get-TeamViewerConnectionReport
    Get-TeamViewerContact
    Get-TeamViewerCustomModuleId
    Get-TeamViewerEventLog
    Get-TeamViewerGroup
    Get-TeamViewerId
    Get-TeamViewerInstallationDirectory
    Get-TeamViewerLogFilePath
    Get-TeamViewerManagedGroup
    Get-TeamViewerManagementId
    Get-TeamViewerManager
    Get-TeamViewerPolicy
    Get-TeamViewerPredefinedRole
    Get-TeamViewerRole
    Get-TeamViewerService
    Get-TeamViewerSsoDomain
    Get-TeamViewerSsoExclusion
    Get-TeamViewerUser
    Get-TeamViewerUserByRole
    Get-TeamViewerUserGroup
    Get-TeamViewerUserGroupByRole
    Get-TeamViewerUserGroupMember
    Get-TeamViewerVersion
    Invoke-TeamViewerPackageDownload
    Invoke-TeamViewerPing
    New-TeamViewerContact
    New-TeamViewerDevice
    New-TeamViewerGroup
    New-TeamViewerManagedGroup
    New-TeamViewerPolicy
    New-TeamViewerRole
    New-TeamViewerUser
    New-TeamViewerUserGroup
    Publish-TeamViewerGroup
    Remove-TeamViewerAssignment
    Remove-TeamViewerContact
    Remove-TeamViewerCustomization
    Remove-TeamViewerDevice
    Remove-TeamViewerGroup
    Remove-TeamViewerManagedDevice
    Remove-TeamViewerManagedDeviceManagement
    Remove-TeamViewerManagedGroup
    Remove-TeamViewerManager
    Remove-TeamViewerPolicy
    Remove-TeamviewerPolicyFromManagedDevice
    Remove-TeamviewerPolicyFromManagedGroup
    Remove-TeamViewerPredefinedRole
    Remove-TeamViewerPSProxy
    Remove-TeamViewerRole
    Remove-TeamViewerSsoExclusion
    Remove-TeamViewerUser
    Remove-TeamViewerUserFromRole
    Remove-TeamViewerUserGroup
    Remove-TeamViewerUserGroupFromRole
    Remove-TeamViewerUserGroupMember
    Restart-TeamViewerService
    Set-TeamViewerAccount
    Set-TeamViewerAPIUri
    Set-TeamViewerDevice
    Set-TeamViewerGroup
    Set-TeamViewerManagedDevice
    Set-TeamViewerManagedGroup
    Set-TeamViewerManager
    Set-TeamViewerPolicy
    Set-TeamViewerPredefinedRole
    Set-TeamViewerPSProxy
    Set-TeamViewerRole
    Set-TeamViewerUser
    Set-TeamViewerUserGroup
    Start-TeamViewerService
    Stop-TeamViewerService
    Test-TeamViewerConnectivity
    Test-TeamViewerInstallation
    Unpublish-TeamViewerGroup
  • grattu
    grattu Posts: 2 ✭✭
    Does anyone know how to get the full list of devices when you run the API? I'm only getting about 1000 of my devices when I run this command but I am getting a  nextPaginationToken which I don't know how to use when I run the command.
    Invoke-RestMethod -Uri /api/v1/managed/groups/{id}/devices -Method Get -Headers @{authorization = "Bearer $apikey"}
