Why all of a sudden, there is no remote ability, only see the screen?
Recently, teamviewer is suddenly a remote view ONLY application. Inside advanced security settings, I found that access control had changed from full access to view and show, I have changed these back to full access. I get the need for netter security, but might be good to tell people, your updates just changed the program significantly, to being only a viewer, instead of remote control. I found with my cell phone, this did not take place. Why would this be done? This is a remote control program and to have that ability suddenly taken away, kinda like a junkie not getting their fix. Tells you how much I love this program and use it to help disabled veterans fix issues with their PC's. Sure hope there is a fix for this soon. Have not found an answer in the forums, only lots of questions.
Janelle Wolves
  • impy
    impy Posts: 3 ✭✭
    same here, lots of mentions of it but no answer. did you find a solution?
