How can I check who logged onto my computer?
eb8885
eb8885 Posts: 2 ✭✭
As I got back to my computer, I saw the Teamviewer alert dialog that says :
"This was a free session sponsored by www.teamviewer.com"
This probably means that someone connected to my computer and ended the session.
How can I search in the Log to know when and how long this session was? And also who connected.
This is quite worrying because the Teamviewer ID is just a sequence of numbers, and the passwords are really short.
  • ruggb
    ruggb Posts: 2 ✭✭
    look at you password. Then close TV completely. Then reopen it. your PW should have changed.
    If you do not close TV or do not shutdown your computer, the previous PW remains active and your previous connection can be re-established without your involvement.
    if TV is setup for remote access then there is a permanent PW. If someone has that they can login without you giving them the changeable password
  • eb8885
    eb8885 Posts: 2 ✭✭
    Thanks for the response.
